Headlamps
Discussions relating to registration issues
expat2000
Headlamps
Post by expat2000 » Fri May 13, 2011 10:10 am
Hi all
As I am planning on exporting my scimitar from the UK to Norway this summer I need to change the headlights from RHD to LHD. Are the headlights a standard (lucas?) part, 7"?
Seem to be lots of LHD MGB headlights on ebay which use H4 and sidelight bulbs, would these be suitable?
Thanks in advance.
Stuart
Living in Oslo without my 1977 SE6A GTE, car was successfully imported and registered then sold as couldn't afford to run it. Now driving a 1998 Audi A4 Estate diesel.
roymck
Has thanked: 15 times
Been thanked: 24 times
Re: Headlamps
Post by roymck » Fri May 13, 2011 10:18 am
If its an SE6 then yes they would fit . But go for Cibie or aftermarket lamps much better , not lucas . Roy
expat2000
Re: Headlamps
Post by expat2000 » Fri May 13, 2011 10:56 am
Sorry should have specified, its an SE6A.
Stuart
Has thanked: 135 times
Been thanked: 499 times
Re: Headlamps
Post by Roger Pennington » Fri May 13, 2011 11:31 am
Unless it's already been done, then if changing the headlights, I'd also look at changing the "nests" (the mounting bowls) to plastic ones, as sold by SVC for example. No more rust!
Return to “Registering a Scimitar”
