GTC Vert Soleil
Been thanked: 435 times
GTC Vert Soleil
Post by Roger Pennington » Sun Oct 01, 2017 7:25 pm
DARK STAR wrote:
Sun Oct 01, 2017 6:46 pm
I've just realised I have no 6b supplement in my genuine 1979 Reliant manual :roll:
That's correct, the manual never included that. The supplement is a separate thing produced by the Club, I'm not sure if it was derived from a Reliant service bulletin or the Ford manual, Jim will probably know?
Has thanked: 113 times
Been thanked: 750 times
GTC Vert Soleil
Post by scimjim » Sun Oct 01, 2017 8:09 pm
Yep, I basically converted the Reliant Service Bulletin (and possibly a couple of pictures from a Ford manual :D ) into modern font and layout.
Been thanked: 61 times
GTC Vert Soleil
Post by gtcse8 » Mon Oct 02, 2017 8:31 am
On my GTC the exhaust uses 2" rubber rings in the centre and figure of 8 at the rear.
Been thanked: 52 times
GTC Vert Soleil
Post by DARK STAR » Mon Oct 02, 2017 11:15 am
Thanks Mark, mine seems to be standard then.
So how have the garage managed to hike up one side and not attach the other :doh:
I'll see if I can attach the low side with the correct rubbers and get some longer ones for the high side ...
Incidentally I'll keep the new ignition module as fitted, to be on the safe side.
Remind me how much with the extras.
GTC Vert Soleil
Post by gtcse8 » Mon Oct 02, 2017 12:18 pm
Ok Chris
The modules are only £50, usually £75 or even more depending upon source.
The insured shipping was £13.20.
You can have the lens as I have about 10 of them left, plus I have about 20 brand new units left.
Cheers Mark
GTC Vert Soleil
Post by DARK STAR » Mon Oct 02, 2017 5:18 pm
Sounds good, I'll send a PayPal :)
philipmasonfrance
GTC Vert Soleil
Post by philipmasonfrance » Mon Oct 02, 2017 5:55 pm
Chris, I picked up a load of exhaust rubbers from Ebay years ago. Don't know why, but it seems the (wait for it) Allegro rubber is perfect. Shall I stick a few in the post?
GTC Vert Soleil
Post by DARK STAR » Mon Oct 02, 2017 6:14 pm
That's kind Phil.
Not sure about having Allegro parts on the car but if it's free ... 8)
GTC Vert Soleil
Post by Roger Pennington » Mon Oct 02, 2017 6:53 pm
The Allegro rubbers have been recommended a number of times in the past on here, as being a more durable aliternative to the standard ones, as they have a more "solid" shape and normally look like this: (image from the web) See here on fleabay
philipmasonfrance
GTC Vert Soleil
Post by philipmasonfrance » Tue Oct 03, 2017 7:05 am
They're the ones, Roger! I got fed up with replacing the rubber hangers almost every year, so tried these. Still on the first set 4 or 5 years later. PM me your address, Chris - and yes, no charge!!
GTC Vert Soleil
Post by DARK STAR » Tue Oct 03, 2017 8:31 am
Thanks Phil, will do :D
GTC Vert Soleil
Post by DARK STAR » Wed Oct 04, 2017 6:30 pm
Today I bought some gun gum and plucked up courage to re-seal the exhaust manifolds.
Surveying the work site I found the answer to my question -
Some idiot (as in the garage at Lyon, because it wasn't like that before) has jacked up the car on the exhaust system.
On the right (which was not attached :roll: ) the pipe is perfectly straight coming from the two-into-one connection.
On the left it kicks up and jams the front box against the floor.
There is no way this can be corrected and seems to me rather dangerous - red-hot fibreglass resin is not ideal.
So I suppose I'd better invest in a sheet of serious heat-shield material from Demon Tweeks and force it in over the silencer box.
Anyway, removing the manifold on the other side was no more :evil: than expected.
What was unexpected was finding THREE different head sizes on the (same thread!) nuts and bolts - 15, 16 and 17 mm.
The smaller size is great for clearing the big-bore exhaust pipes, only I have no 15 mm spanner 8)
The upper nuts/bolts are easy with a long extension on the socket wrench but the lower ones are behind the pipes and impossible without an open-ended spanner.
Even then one is working half a flat at a time.
So several hours work to do very little, and even more irritating because I already had to do the job when I bought the car.
Tomorrow we'll see if it works ...
PS See if you can guess which gasket was leaking, and in the second photo spot the not-so-deliberate mistake - think which direction the manifold has to move to come off :wink:
Been thanked: 198 times
GTC Vert Soleil
Post by AJL Electronics » Wed Oct 04, 2017 6:37 pm
I hope that is assembly paste and not repair paste Chris? There is an important difference.
Extender arrived yesterday and is fitted, thanks kindly.
GTC Vert Soleil
Post by DARK STAR » Wed Oct 04, 2017 6:45 pm
I hope so too, but the french are not very technical.
It is quite liquid in a tube, has instructions for use in assembly and it is rated to 1000º ...
I even had to order the electric glue abroad, no-one has ever heard of it round here.
GTC Vert Soleil
Post by gtcse8 » Wed Oct 04, 2017 10:37 pm
Bloody hell Chris bet you wish you were back in Yorkshire with all the Industrial Revolution Inventiveness and knowledge here Ha Ha.
It`s p*ssin it down here now 11.40pm.
Thanks for the money transfer.
Return to “Projects”
