Tar remover recommendations
Has thanked: 23 times
Been thanked: 85 times
Post by swoakes » Sat Feb 13, 2016 12:22 pm
Can anyone recommend a good product....the white daily drivers are covered in tar at low level.
I had some years ago that you sprayed on, it dissolved the tar and you just wiped off. Can't remember what it was called :roll:
DavePoole
Been thanked: 23 times
Re: Tar remover recommendations
Post by DavePoole » Sat Feb 13, 2016 12:31 pm
I'm sure the late Chris Lloyd used to say WD40 did the trick?
Been thanked: 326 times
Post by peter freeman » Sat Feb 13, 2016 1:26 pm
White spirit ?
Has thanked: 147 times
Been thanked: 155 times
Post by Corky » Sat Feb 13, 2016 1:42 pm
I use the autoglym stuff. Very good indeed.
Post by toomanysabres » Sat Feb 13, 2016 2:36 pm
White spirit has always been the recommended stuff at least it will be the cheapest option to try I would think.
Post by swoakes » Sat Feb 13, 2016 3:15 pm
Corky wrote:I use the autoglym stuff. Very good indeed.
Tried that today Steve; applied to the tar, left if for a while and you still had to rub hard to remove even small spots :(
Post by Corky » Sat Feb 13, 2016 3:55 pm
Tar that's been on a while does take a bit of time but I wouldn't rub too hard, just soak a little longer. If you catch it within a few days though, it just wipes off.
I've tried the Halfords own version and it was a complete waste of money. I've also tried the wipes, which were useless too.
Post by swoakes » Sat Feb 13, 2016 4:40 pm
Corky wrote:I've tried the Halfords own version and it was a complete waste of money. I've also tried the wipes, which were useless too.
Yep don't want to waste my money :wink:
PoshTwit
Post by PoshTwit » Sat Feb 13, 2016 4:45 pm
Krystal Kleen Details Tar-tastic is a mild, spray gel tar remover.
Spray it onto the car and then ignore it for 5, 10, 15, 30 minutes depending how much tar there is, wipe with a microfibre and rinse well.
I have left this stuff on a panel of my van as a trial in direct sunlight for an hour with no ill effects.
There are other ones I use but this is the best suited for all round use particularly on more delicate finishes.
Been thanked: 473 times
Post by Roger Pennington » Sat Feb 13, 2016 8:19 pm
PoshTwit wrote:Krystal Kleen Details Tar-tastic is a mild, spray gel tar remover.
Does it affect any existing polish/wax/sealant finishes applied, or does it only remove the tar, and leave the rest intact?
Darren C
Post by Darren C » Sat Feb 13, 2016 8:28 pm
Cif cream, my best kept secret.
Supermarket home brand 89p
Ideal for tar spots, baked on brake dust on alloys, baked on squashed flies in summer, cleaning rust stains & spots off Chrome and cleaning light colour leather interiors. :D
@classiccarguru1
Been thanked: 854 times
Post by scimjim » Sat Feb 13, 2016 9:05 pm
and taking a layer of paint off - it's more abrasive than Farecla G3 :shock:
Darren C
Post by Darren C » Sat Feb 13, 2016 9:28 pm
Nope, that's an urban myth, you're thinking of Ajax.
@classiccarguru1
Post by scimjim » Sat Feb 13, 2016 10:13 pm
PoshTwit
Post by PoshTwit » Sun Feb 14, 2016 6:37 am
Roger Pennington wrote:Does it affect any existing polish/wax/sealant finishes applied, or does it only remove the tar, and leave the rest intact?
Any product that dissolves tar will affect a natural wax or polymeric product. It will most likely not completely remove it (the only sure fire way to do this is to use a light abrasive compound) but it will weaken it.
Given that you would probably only do a full decontamination involving such a product on a maximum of a quarterly basis then re-applying your protection afterwards should be done as a matter of course.
If you have invested in a glass or ceramic coating you should not have affected it.
Return to “Polishers' Corner”
