Cleaning advice please.
oldynewby
Post by oldynewby » Thu Apr 23, 2015 4:51 pm
Hi All,
I'm in the process of recommissioning my SE6 (ORF 876P), hopefully for May 1st but I need to give it a bit of a dusting off first.
To my shame it's been festering on my drive for about 2 years as I didn't use it last year, and it's covered in all sorts of moss and gritty nastiness which needs to be removed before I can proceed with the shampoo, clay, colour restorer, what have you.
Having researched this on a few forums, my plan is to jetwash the grit and moss from a distance to shift it prior to snow-foaming the car with Demon Foam. Afer a proper wash with Auto Glym shampoo using the 2 bucket method I'll use Meguires clay bars and Quik Detailer as a lubricant, followed by a going over with G3 Colour Restorer using their waffle pads. Lastly a good dose of Auto Glym SRP.
My main concern is that I don't create further scratching while removing the grit and moss. Should I use the jetwash or a normal hose? Also would it be safe to use a soft brush to help shift the crud?
I've never set out to clean a car to this level before so any help/ comments would be very much appreciated.
Thanks, Paul
1976 GTE SE6 ORF 876P
2010 Ford Mondeo 2.0 Titanium X Estate
Previous classics: 1972 Sunbeam Imp Sport, 1968 Sunbeam Stiletto
scimmy_man
Been thanked: 43 times
Re: Cleaning advice please.
Post by scimmy_man » Thu Apr 23, 2015 5:25 pm
try TFR before the jetwash
oldynewby
Post by oldynewby » Thu Apr 23, 2015 5:47 pm
TFR? The Fat Rabbi, Tiny Furry Rabbits, Ten Frogs Ribbeting...?
Has thanked: 106 times
Been thanked: 807 times
Post by philhoward » Thu Apr 23, 2015 6:03 pm
Traffic Film Remover
oldynewby
Post by oldynewby » Thu Apr 23, 2015 6:16 pm
Thanks for that Phil, although I'm not sure that's what it needs as a first stage. The crud on the car is mostly sand and grit, Sahara dust if you like. It'll need to be addressed before anything else. Perhaps TRF as the second stage.
Cheers.
Paul.
windy
Been thanked: 41 times
Post by windy » Thu Apr 23, 2015 6:25 pm
Get everything wet & leave it wet for an hour or 2 before jet washing so as to give the crud time to loosen its grip.
Best not done on a sunny day.....
PoshTwit
Post by PoshTwit » Thu Apr 23, 2015 7:55 pm
Please do not resort to TFR. That is what your £5 hand wash Johnnies use to strip tar spots, etc from your wheels and lower panels so spraying it all over the car is far from recommended.
I suggest you try a citrus-based pre-wash such as that made by ValetPro. It can be diluted to suit and is rather milder to your paint than TFR would be.
As Windy suggested, keep it wet with your pre-wash mixed in a pump sprayer and then rinse off the worst that it has lifted. Then go with your snowfoam, rinse, 2-bucket wash, rinse and then pat dry.
If it were me, I would be using steam to soften and gently remove the detritus from the bodywork (especially if there is grease or oil present) before then going for a pre-wash, rinse, 2-bucket wash, rinse and pat dry.
Do get in touch through my website if you would like any further assistance.
oldynewby
Post by oldynewby » Thu Apr 23, 2015 9:18 pm
Thanks for the advice Rich, and thanks for the offer. I plan to do it this weekend so we'll se what the weather's like. Just my luck it'll be blazing sunshine!
Return to “Polishers' Corner”
