Towing with a 6a
Do you know of a good site?
Coastline
Has thanked: 24 times
Towing with a 6a
Post by Coastline » Thu Oct 29, 2015 5:02 pm
Thinking ahead for next years hols I was contemplating towing a small caravan and was wondering what the maximum weight I could tow with my 6a. I have read that the caravan should not exceed 85% of the kerbside weight of the tow car. Is this correct and what is the kerbside with of my 6a please. Do I need any insurance for the caravan. Any advice would be much appreciated. Thanks.
speedy555
Has thanked: 52 times
Re: Towing with a 6a
Post by speedy555 » Thu Oct 29, 2015 5:22 pm
The 85% is just a guideline, though a very sensible one. Many modern cars can tow well in excess of their kerbweight if you're daft enough, and the trainweight isn't exceeded.
Im not sure on the weight of a 6a, but as far as the caravan goes it is the MTPLM weight you should work off (i.e. max fully laden weight)
Im a bit of a caravan anorak :) and have a facebook page UK Caravanners
https://www.facebook.com/groups/ukcaravanners/
Dave Speed
1970 se5 1975 se5a
Prev. ss1 ti / 68 coupe/ 77 & 78 6a / 9x 5a's / '85 SS1 /87 SS1 1.3/ 2x '81 6b's / Cipher / 3 x 69 se5 / rialto / Rochdale Olympic
www.ssgclassics.co.uk
www.scimitarpaint.co.uk
www.facebook.com/ssgclassics
Been thanked: 578 times
Post by philhoward » Thu Oct 29, 2015 5:51 pm
With the grunt of the engine and the short rear overhang, a Scim is capable of towing over and above what you might think but I'd guess that 1200kg on the back won't be a problem?
speedy555
Post by speedy555 » Thu Oct 29, 2015 6:13 pm
Its the old tail wagging the dog scenario you want to avoid :) The lighter the caravan, the safer it will be!
Dave Speed
1970 se5 1975 se5a
Coastline
Post by Coastline » Thu Oct 29, 2015 7:16 pm
I thought an old 2 berth Sprite caravan from the 1970's would look appropriate plus these early caravans are not that heavy. I also like the Eriba range but they are quite pricey. If anyone discovers the kerb side weight of a 6a please drop a note. Wikipedia list it as 2,762 lb.
speedy555
Post by speedy555 » Thu Oct 29, 2015 7:58 pm
If it is 2762lb then that's about 1253kgs, so ideally a caravan with a laden weight below 1065kgs, which shouldn't be too tricky with an older caravan....pre 70's they were generally heavy, went light in the later 70's / early 80's, then turned slowly into fatties by the late 90's/early 00's, and have been dropping again since.
Dave Speed
1970 se5 1975 se5a
Been thanked: 225 times
Post by AJL Electronics » Thu Oct 29, 2015 8:36 pm
Cheltenham Sable or Fawn.
Has thanked: 134 times
Been thanked: 497 times
Post by Roger Pennington » Fri Oct 30, 2015 12:53 am
Hi Michael, The Se6a weights from the Reliant Workshop Manual are as follows:
Hope that helps :)
speedy555
Post by speedy555 » Fri Oct 30, 2015 9:50 am
I wasn't far out then :) 1016kgs it is.....
Dave Speed
1970 se5 1975 se5a
Coastline
Post by Coastline » Fri Oct 30, 2015 1:39 pm
Roger Pennington wrote:Hi Michael, The Se6a weights from the Reliant Workshop Manual are as follows:
Hope that helps :)
Brilliant. Many thanks Roger.
Return to “Camping & Caravanning Info & Sites”
