Everything you ever wanted to know about petrol.....
Been thanked: 854 times
Re: Everything you ever wanted to know about petrol.....
Post by scimjim » Thu Jun 04, 2015 6:28 pm
Dennis Nicholas wrote:From my notes after a bit of research 2013.
SAE J30R6 (early 80s) not really for ETHANOL
SAE J30R9 hose for use with Bio ETHANOL up to 50%
I'm afraid your notes are wrong Dennis - link to SAE specification here
Essentially R6 is okay for carbs and over 5% ethanol, R9 is rated for higher pressure of injection systems and R10 is for systems where the hose is immersed in fuel (inc bio/ethanol)
Been thanked: 473 times
Post by Roger Pennington » Thu Jun 04, 2015 7:39 pm
Yes, personally, I too prefer the screw-type clips, of the type specifically made for fuel hose, (like those illustrated above). The spring clips I've always found too fiddly and not really confidence-inspiring (as Phil says, you can't adjust the tightness for different sizes of hose).
Dennis Nicholas
Has thanked: 17 times
Been thanked: 20 times
Post by Dennis Nicholas » Sat Jun 06, 2015 3:53 pm
Essentially R6 is okay for carbs and over 5% ethanol, R9 is rated for higher pressure of injection systems and R10 is for systems where the hose is immersed in fuel (inc bio/ethanol)[/quote]
Hi Jim
That was part of my read up.
I think you may have misread those specs....the last bit of the R6
"Exposure of these hoses to gasoline or diesel fuel which contain high levels, greater than 5% by volume, of oxygenates, i.e., ethanol, methanol, or MTBE (methyl tertiary butyl ether), may result in significantly higher permeation rates than those listed for 30R6, 7, or 8."
I take that to mean that you would get higher permeation rates than the rates listed for R6 with ordinary petrol.
The pressure part of the spec is of course of no interest to our low pressure systems.
Anyway at under £5 per meter for R9, the cost of renewing just under 2 meters is not too horrendous.
Dennis
Dennis Nicholas(RSSOC)
Dennis Nicholas
Post by Dennis Nicholas » Sat Jun 06, 2015 3:59 pm
Roger Pennington wrote:Yes, personally, I too prefer the screw-type clips, of the type specifically made for fuel hose, (like those illustrated above). The spring clips I've always found too fiddly and not really confidence-inspiring (as Phil says, you can't adjust the tightness for different sizes of hose).
I agree those stainless screw type specially for fuel hose would be better but have not been able to find a supply.
The main point I was trying to get across was not to use ordinary Jubilee clips
Dennis
Post by toomanysabres » Sat Jun 06, 2015 4:08 pm
Dennis Nicholas wrote: I agree those stainless screw type specially for fuel hose would be better but have not been able to find a supply.
Dennis
Various sizes here http://www.carbuildersolutions.com/uk/f ... genumber=2
Been thanked: 213 times
Post by AJL Electronics » Sat Jun 06, 2015 4:10 pm
And available from my site.
Been thanked: 539 times
Post by philhoward » Sat Jun 06, 2015 4:59 pm
...and eBay...
Post by toomanysabres » Sat Jun 06, 2015 5:06 pm
Devon is a long way and the wet string keeps drying out. :lol:
Post by scimjim » Sun Jun 07, 2015 4:19 pm
scimjim wrote:I'm afraid your notes are wrong Dennis - link to SAE specification here
Hi Jim
Dennis
I didn't misread it Dennis, I read the whole spec sheet and summarised it (above). UK fuel is CURRENTLY 5% max, so R6 is the MINIMUM requirement - and some of us have Scimitars with high pressure systems, so the pressure part of the spec is very important.
