Am I inhibited ?
Has thanked: 178 times
Been thanked: 1228 times
Am I inhibited ?
Post by scimjim » Mon Jul 22, 2019 12:39 am
Have you checked the starter relay for power yet? It’s behind the glove box on a 6 series/GTC.
Korporal brunhausen
Am I inhibited ?
Post by Korporal brunhausen » Mon Jul 29, 2019 11:42 am
thanks Scimjim, I hadn't got that far cos I couldn't make any progress with the r/inhibitor due to access probs. there's power in the wire to it.
I've now done the starter relay as you suggested and the relay functions and there is power there. I think I'll look at the solenoid next. I still have the r/inhibitor prob to sort, I can't even get the lead back on!
Can you confirm that I am right in assuming that the order of things is the ignition switch, inhibitor, starter relay, starter relay ,solenoid relay, and solenoid itself?
Many thanks all.
Am I inhibited ?
Post by scimjim » Mon Jul 29, 2019 12:29 pm
Wiring diagram here
Order is: Ignition switch, starter relay, starter solenoid. The inhibit/reverse switch provides an earth to the starter relay when it’s in the correct position (neutral or park) so if you don’t have the plug on it, the starter relay shouldn’t energise.
Has thanked: 219 times
Been thanked: 47 times
Am I inhibited ?
Post by willholderogri » Mon Jul 29, 2019 1:14 pm
If the plug is off just short the pins out this should eliminate the inhibitor switch .make sure it's in neutral because if it fires up the car will start moving .
Am I inhibited ?
Post by scimjim » Mon Jul 29, 2019 2:08 pm
I think it’s a 3 pin switch as it’s the reverse switch too, so you have to short the correct two 😀
Korporal brunhausen
Am I inhibited ?
Post by Korporal brunhausen » Mon Aug 19, 2019 10:24 am
I've had a.bit RNR from my non cranking SE6 by tidying up the engine bay, time well spent etc. The immobiliser is the Thatcham approved Autowatch 239 TI which appears to be functioning normally, BUT when I Googled this I found some reference to symtoms the same as I've got. When they came to start they couldn't get the starter to turn.....
Has anyone ever had this prob with a scim?
Meanwhile,with newly reacquired enthusiasm, I'm working my way back thro those 40 odd year old wires more thoroughly with the hope of more progress.
Also, has anyone any idea of which two of the three wires on the inhibitor ( or red/ white , green and green/brown) I would need to short out to bypass it?
MAny thanks for all the help thus far.
Korporal brunhausen
Am I inhibited ?
Post by Korporal brunhausen » Sat Oct 05, 2019 6:29 pm
MY NON TURNING SE6 HAS TURNED AT LAST!!! SHOCK HORROR.
I did this by bypassing the reverse safety switch and the solenoid wiring etc ( low voltage on the White/red wire) to get temporarily mobile to get to a garage to investigate the cause of the starting probs.
Can anyone confirm just what wires on the safety switch have to be shorted ?
Many Thanks
Am I inhibited ?
Post by scimjim » Sat Oct 05, 2019 7:10 pm
Looking at the wiring diagram, you need to Earth the red/white at the inhibit switch. This powers the starter relay, which sends power to the starter solenoid (brown to brown/red) when you turn the key.
Korporal brunhausen
Am I inhibited ?
Post by Korporal brunhausen » Sun Oct 13, 2019 11:39 am
Thanks Jim, as usual I have been doing things wrongly.
I've decided it might be a good idea to replace the neutral safety switch,but looking round the electric interweb (!) there doesn't seem to be much to see,but I'm probably just looking in all the wrong places as usual. Do you have any ideas pl?
John B.
Am I inhibited ?
Post by scimjim » Sun Oct 13, 2019 5:27 pm
Do you mean an alternative to the existing reverse/neutral switch, or a source for originals?
Korporal brunhausen
Am I inhibited ?
Post by Korporal brunhausen » Tue Oct 15, 2019 11:11 pm
Hi Jim, my intention is to replace the switch with a new one. I 'm not having much luck searching for the replacement. Out of curiosity, is there an alternative ??
John B.
Am I inhibited ?
Post by scimjim » Wed Oct 16, 2019 9:05 am
Never heard of anyone fitting an alternative, although I don’t think I’ve ever heard of one failing either? Have you tried the club traders? I’m sure there will be plenty of s/h ones available if you put a wanted ad out.
Has thanked: 79 times
Been thanked: 212 times
Am I inhibited ?
Post by gtcse8 » Wed Oct 16, 2019 6:42 pm
I have changed a few over the years.
Jim they do fail, but the hardest part is getting the astard off, they use an ally washer to seal the casing and tend to be very tight.
John I`m surprised you can`t find any on line, they fit a lot of Fords.
Am I inhibited ?
Post by willholderogri » Wed Oct 16, 2019 8:01 pm
I made a special u shaped spanner it. Made it easier
Korporal brunhausen
Am I inhibited ?
Post by Korporal brunhausen » Sat Nov 23, 2019 8:08 pm
Still not having any luck finding a replacement neutral safety switch ,can anyone give me any pointers to rectify this prob please? The place I haven't tried yet is Ford themselves.
I have a couple of other minor type queries I would appreciate advice on,
I last did the "tappets" on my last SE5 back in 1977, and I can't for the life of me remember how I need to number the valves for the adjustment and I don't want to do the job twice!! Could some soul remind me?
My tail gate struts are useless, can anyone tell me the standard fit pl?
Once again I appreciate the help you guys are offering.
John B.
