Vertical link/stub axle nut and washer
Dennis Nicholas
Has thanked: 64 times
Been thanked: 35 times
Post by Dennis Nicholas » Mon Jun 03, 2019 3:30 pm
Another detail query.
The stub axle is held onto the vertical link by a nut with a plain washer under it.
The now dished washer is 0.091 inches thick. (by micrometer)
Vertical link hole is 0.821 inch (By digital calliper)
1/2 UNF nut is 0.7475 inch across the flats and 0.8545 across the points.
It can be seen that in picture 1 the washer has been dished into the vert. link hole by the tightening of the nut on the stub axle. The bright ring witness ring marks on nut and washer where the two mate can be seen in picture 2.
Picture 3 clearly shows that the across the flat measurement of the nut is less than the diameter of the vert. link hole which is why the washer has dished in.
Nut with washer standing on edge to show dishing
Nut and washer showing witness marks where dishing and nut face correspond.
showing nut across flat measurement smaller than stub hole diameter.
This seems poor engineering. Should there be a much thicker washer that will not dish, or even better a specially larger across flat sized nut?
Using a digital calliper seems to show that, with the stub only pushed in hand tight, there would only be room for an extra thickness of 0.0095 on the washer before the end of the thread. This would give a washer thickness of 0.1605......could probably allow a bit thicker with stub pulled tighter onto taper.
I am a bit concerned since (only on one occasion) I had a stub axle come loose. I had not done any work on that car so not due to me incorrectly torquing down nut. Mindful in view of the battering we now get from potholes!
Dennis
Dennis Nicholas(RSSOC)
Been thanked: 69 times
Post by Old and Slow » Mon Jun 03, 2019 4:36 pm
Here's a dimensional diagram from the TR4/4A manual.
Not very helpful as it doesn't give the exit hole diameter nor the taper angle.
TR4A_suspension.docx
(177.95 KiB) Downloaded 39 times
Has thanked: 77 times
Been thanked: 706 times
Post by philhoward » Mon Jun 03, 2019 9:49 pm
I don’t know the exact relative positions of mating faces but I see one of 3 possibilities:
1. The shoulder of the stub axle sits below the back face of the vertical link, so the washer and the stub axle shoulder shouldn’t touch. Gap exists between washer and stub axle.
2. The shoulder of the stub axle protrudes through the vertical link a little, so the washer should fit over the shoulder of the stub axle.
3. Someone has in the past had play in the stub axle and instead of replacing it (or the vertical link), just wound the nut up tighter and tighter? It could after this exercise (and not getting rid of the play) the faulty part was replaced but not the washer?
Once tightened, all the stresses will be on the taper - over-tightening the nut will achieve nothing (apart from distortion) so I don’t think there’s an engineering issue, just a bad mechanic issue in the past. Replace the washer with the same and assemble it correctly and it will be fine.
Dennis Nicholas
Post by Dennis Nicholas » Mon Jun 03, 2019 11:27 pm
Afraid it does not show the washer and nut in question either, or stub axle.
RonH
Post by RonH » Tue Jun 04, 2019 6:56 am
Hi Dennis
What is the inside and outside diameter of the washer?
Also what is the thread spec of the nut or stub axle?
Has thanked: 37 times
Been thanked: 164 times
Post by gtcse8 » Tue Jun 04, 2019 8:15 am
I would agree Phil
No need to tighten a nut to the point of bending the supporting washer, the tapered stubs are just as prone to sticking as the rear hubs on half shafts.
Dennis I am looking at your request for the parts, but been a bit busy with Dr`s and hozzy`s.
EX SST 1800Ti
JoeySully
Been thanked: 32 times
Post by JoeySully » Tue Jun 04, 2019 9:47 am
I replaced the same nut and washer recently and torqued it to the correctly as per the WM. I removed it the day after and found the new washer was bent too.
All 4 i have removed have all been bent. the stub axle does not lie flush with the rear of the upright. If it did then it may rotate when tightened up.
Dennis Nicholas
Post by Dennis Nicholas » Tue Jun 04, 2019 10:58 am
Hi Dennis
Measuring with digital callipers. all in inches
Washer I/D 0.506
Washer O/D 1.115
Thin end of stub axle taper 0.833
Vertical link hole diameter at thin end 0.8215.
Thread is half inch UNF 20 TPI.
Showing stub pushed in hand tight....shoulder below link surface.
nut and washer in place (nut not screwed down)
Dennis
Dennis Nicholas
Post by Dennis Nicholas » Tue Jun 04, 2019 11:02 am
This seems to be the norm then?
Dennis
JoeySully
Post by JoeySully » Tue Jun 04, 2019 11:56 am
Yes it does seem to be the norm. I doubt it matters, because as the stub axle is pulled into the upright they instantly seize together so well that the only way to separate them is to wallop it whit a big hammer and destroy the threads !
justfur
Post by justfur » Tue Jun 04, 2019 12:08 pm
Pretty sure his was standard fitment as when removing the stub axle from the vertical link, so as to not destroy the threads, a socket or pipe is placed over the threads to make contact with the stub axle inside the vertical link.
Justin.
1976 SE6 no.49 See more here: https://www.flickr.com/photos/147918531 ... 463353942/
1963 CV8 Mk1 no.10
1967 TR4A
JoeySully
Post by JoeySully » Tue Jun 04, 2019 12:18 pm
ahh that's what I'm doing wrong. makes sense. They are very soft.
Dennis Nicholas
Post by Dennis Nicholas » Tue Jun 04, 2019 12:42 pm
Lucky enough to have a hydraulic press. I put an old plain nut on end flush and pumped away.....big bang and stub release, unfortunately sooner than expected so did not see what pressure on gauge. The stub/nut was free of the press mandril by a gap so the mandrill did notactually push the nut down into the vert. link, BUT it was noticed that the nut had been fired about halfway down its length into the opening with 6 neat little ears poking off the nut corners :shock: will try to remember to watch gauge when doing drivers side.
Post by Old and Slow » Tue Jun 04, 2019 3:43 pm
Other pictures in the TR4 Manual show the nyloc nut and washer to the rear of the upright, but they appear screwed up tight and don't take us any further.
I'll look to see if a torque setting is quoted.
Post by Old and Slow » Tue Jun 04, 2019 3:50 pm
Here's a copy of the relevant page, hope it is useful!
TR4A_suspension_2.docx
(212.32 KiB) Downloaded 26 times
55-60 Lbft is the figure, probably the same for all later models using trunnions etc.
