Engine Rebuild Novice
IanC
Post by IanC » Fri May 24, 2019 3:28 pm
this helpful diagram shows the additional red and white wires from the starter inhibit on an auto car, but does anyone know where the wires physically join the starter (if in fact they do)? The wiring on the car is a bit of a jumble in the vicinity of the starter with repairs apparently made with whatever colour was to hand so it's taking a bit of sorting! Having said that, I'm hopefully o the home straight now (famous last words)!
Current : SE5a 4spd auto project
Post by gtcse8 » Fri May 24, 2019 6:42 pm
Plugs into the Reverse Inhibitor switch on the Left of the auto box, just behind the bellhousing.
IanC
Post by IanC » Sun May 26, 2019 11:22 am
The unexpected issues are coming thick and fast now that I've got the engine back in, battery, ball joints, brakes, shocks and now the carburettor. All surmountable if unwelcome, but the carb issue is a weird one.
I noticed the sector wheels on the back only went to halfway. After a bit of persuasion they went to a full quarter turn and then stuck, leaving the butterflies in the fully open position :shock: What is happening is that the accelerator diaphragm is difficult to move, and the cam is jamming against the operating lever. Swapping the diaphragm for another (old) one cures the issue, but I can't figure out what's going wrong. The only difference I can see is that the 'good' diaphragm's telescoping bit is lightly sprung, whereas the troublesome one's telescope bit is very firmly sprung. It isn't sticky or jammed, it just takes a real push to overcome the tension of the internal spring.
The photos show the cam, operating lever and diaphragm in the 'problem' position, plus another one showing how the carb can stick open.
The carb in the photo is an old one which gave up its diaphragm to cure the carb on the car, but the problem has now been transferred to the old carb along with the newer, possibly faulty diaphragm.
Any thoughts?
carb jammed open
Cam lever and diaphragm
IanC
Post by IanC » Tue May 28, 2019 10:04 am
Being a bit of a PITA here, but yet another question, this time concerning the gearbox, an A4LD unit with C3 T/C and cable kickdown. I've reconnected the cable at the same setting as it was left by the PO, but this restricts the operation of the carb to half way opening. The reason for this is the K/D lever on the box has only 1 cm. travel of arc at the top of the lever. I know it's not a C3 box, but when i have adjusted a cable on one, IIRC the lever had a very significant sweep of travel.
If anyone has experience of working on A4LD boxes, could they advise if this short travel is normal and the cable must be adjusted to suit, or is there a problem?
Thanks in advance,
Ian
IanC
Post by IanC » Sat Jun 15, 2019 1:45 pm
Any thoughts?
Answering my own question here for anyone that's interested, the diaphragms on both were past their sell by date and the only reason the older one allowed the actuating arm to move, was because it was torn. I'm sure you can guess how I found out...
IanC
Post by IanC » Wed Jun 26, 2019 12:08 pm
OSM 205M is finally moving under its own steam and on the road, after 4 months of steep learning curves. It's a pleasant change to have an auto Scimitar doing over 50 at 2000 rpm rather than the more usual 40ish. Having said that, the gearbox is incontinent front and back, so I'm not finished yet...but many thanks to all who have answered my incessant questions and volunteered advice, I'd have been stuck otherwise.
