Engine Rebuild Novice
ScimiTom
Post by ScimiTom » Sat Mar 09, 2019 8:26 pm
Diyhell wrote:
Sat Mar 09, 2019 7:40 pm
Hear, hear! And as someone who appreciates number plates, that one is an absolute cracker! OSM 205M; so in other words it looks like 'Osm 2 Osm' or 'Awesome to Awesome', almost like 'going from strength to strength'. Best of luck with the engine fitting, and enjoy that stunning car! 8)
Tom
PS - Or, it could be someone's comment on your car... It's 'awesome... TOO awesome'! :)
Current: 'Boffin' (1971 SE5a)
IanC
Has thanked: 61 times
Post by IanC » Sat Mar 09, 2019 8:37 pm
Thanks for that diy, it looks like a good one, i bought it as a stalled project. Hopefully after I've got the engine sorted it won't need too much more to get it up and running. Time will tell!
Ian
Current : SE5a 4spd auto
IanC
Post by IanC » Sat Mar 09, 2019 9:02 pm
Diy, Tom, thanks for your kind comments , coincidentally my wife spotted the osm 2 osm possibility. I only saw the familiar SM being from my, or should i say our part of the world.
Ian
IanC
Post by IanC » Sat Mar 16, 2019 2:39 pm
I'm just plucking up the courage to start putting things together, and I've run into a bit of a mystery. In both the workshop manual and GWs parts catalogue the front crank oil seal (part 39 in the picture) is shown behind the crank gear. However the only place I can see that a front oil seal would fit is in the front cover i.e. in front of the gear. Are the pictures misleading or am I getting in a muddle?
TrevorG
Has thanked: 35 times
Been thanked: 44 times
Post by TrevorG » Sat Mar 16, 2019 3:50 pm
I think it's illustrators licence....look at the page in the parts list where the front cover is shown and the front cover oil seal is positioned as you suggest
IanC
Post by IanC » Sat Mar 23, 2019 7:44 pm
Well, made some progress, crank and pistons in, very satisfying. Here's hoping I've put things together properly. Oil pump next,the 'kit' came with a shiny new one, but not a drive shaft which I'll need to source. However I don't have the clip that retains the shaft in the pump, and it doesn't appear in the Burtons catalogue. I haven't yet tried the usual traders, but before I do, does anyone know if the clip is an obscure or hard to locate part?
Claggy piston
shiny pistons
Has thanked: 64 times
Been thanked: 196 times
Post by gtcse8 » Sun Mar 24, 2019 8:51 am
Think I have both Ian. will look today.
IanC
Post by IanC » Tue Mar 26, 2019 1:43 pm
Yet more questions. I see from this site the importance of ensuring a good seal between oil pump and pick up pipe, and i have a gasket for this. However i don't have one in my 'kit' to go between pump and block. Also I can't see one in various manuals or even my 1990's GW CD Rom (yes I am that old). While I can easily make one, is it advisable to have one fitted , or will a smear of Wellseal be enough (or metal to metal) ?
TIA, Ian
Has thanked: 31 times
Been thanked: 124 times
Post by Coupe Racing » Tue Mar 26, 2019 2:05 pm
I have never seen one or fitted one but ensure but surfaces are very flat
Any sealant that get dislodged could block an oil way
IanC
Post by IanC » Tue Mar 26, 2019 3:22 pm
OK, thanks for that.
Ian
Post by gtcse8 » Tue Mar 26, 2019 6:01 pm
Ian very sorry but can only find the spring clip.
And there is no gasket between the pump and block, I just put a smear of Blue Hermetite round the pump before fitting.
IanC
Post by IanC » Wed Mar 27, 2019 1:42 pm
Today's niggle. The attached photo is of a part from my (previously sealed) gasket kit labelled 'Ford conversion kit Essex'. I think I can see where all the other gaskets/seals go, but not the one in the photo. I've checked various manuals and diagrams and can't see anything like it - but if I was a conspiracy theorist I'd say a prankster has put a Cologne bit in the packet as it looks like a rear bearing cap gasket from a 2.8 engine. I am a bit concerned though as the diameter is similar to the Essex rear crankshaft oil seal - any thoughts?
mystery seal
Has thanked: 240 times
Been thanked: 182 times
Post by b.c.flat hat » Wed Mar 27, 2019 2:11 pm
Think you're right Ian, I've not seen that in all the essexs through my hands.
IanC
Post by IanC » Wed Mar 27, 2019 2:32 pm
Thanks for that BC, I'll put it in the box marked 'bits left over at the end of rebuild' !
Has thanked: 73 times
Been thanked: 102 times
Post by Oldconn » Wed Mar 27, 2019 3:38 pm
It looks remarkably like the crankshaft nose seal for the Mini I have just rebuilt!
