GTE Pedal Boxes
Has thanked: 327 times
Been thanked: 157 times
GTE Pedal Boxes
Post by MikeyBikey » Fri Feb 22, 2019 8:22 am
It failed, sucking brake fluid into engine, very impressive on the overrun . I have two girlings sat on my shelf needing a refurb.
But a while back I bought a brand new Land Rover bulkhead servo as an idea, so it’s sat on the same shelf as the knackered girlings.
But Phil you are probably right, (again). Better get the original refurbed.
Has thanked: 190 times
Been thanked: 37 times
GTE Pedal Boxes
Post by willholderogri » Fri Feb 22, 2019 9:11 am
philhoward wrote:
Thu Feb 21, 2019 9:43 pm
So what’s wrong with the original type servo? Even if you go dual circuit, you can get remote dual circuit servos..
Phil what is required to go down this route I am interested
Will
Has thanked: 78 times
Been thanked: 707 times
GTE Pedal Boxes
Post by philhoward » Fri Feb 22, 2019 9:25 am
If you found a dual circuit master cylinder which fits in the original location/pedal box, there are dual circuit servos which look like 2 “normal” units back to back. Pipe one circuit to one half, and the other circuit to the second half.
The one I’ve seen is this one: https://www.carbuildersolutions.com/uk/ ... rake-servo
