Shock absorbers, esp. bushes
simmit
Has thanked: 117 times
Post by simmit » Fri Jul 14, 2017 10:56 pm
I'm looking to replace shock absorbers (Middlebridge/ Se6) and hear horror stories in particular about poor quality rubber bushes supplied. I do not want poly bushes and I don't need racing quality shocks, just good quality road going jobbies.
Shock absorbers must have (1) adjustable spring seats to accept the original springs (diameters and lengths), (2) have variable damping control, (3) good rubber bushes.
So, of the regular suppliers who do we think has best offering?
Has thanked: 110 times
Been thanked: 726 times
Re: Shock absorbers, esp. bushes
Post by scimjim » Sat Jul 15, 2017 12:53 am
AVO had a problem with poly bushes many years ago - all sorted now AFAIK. I've used Gaz (a long time ago), Spax (on almost all of my cars now after a tour of the factory by the Scimitar owning tech director) and Protech (alloy bodied on G97, much cheaper than you'd think and a small company who are really nice people to deal with), all of which meet your requirements.
Been thanked: 199 times
Post by AJL Electronics » Sat Jul 15, 2017 7:08 am
I am a dealer for Spax so can help if you want some.
Been thanked: 56 times
Post by gtcse8 » Sat Jul 15, 2017 11:49 am
They are ALL *****.
I can post pictures of Mick Gaughrans Avos and Gaz shockers with knackered bushes, including the ones you fitted Andy.
Jim I actually rang Mark at Gaz and he told me they had NEVER had a complaint?????. and if we sent them back they would take a month to rectify.
So I bored out the BRAND NEW Gaz and fitted Proper Bonded bushes to OE spec
Post by AJL Electronics » Sat Jul 15, 2017 12:04 pm
Those bushes were the latest ones that AVO had been issuing specifically to sort the distortion problem. Very disappointing that genuine factory replacement bushes have failed so quickly. So far I haven't seen the problem on Spax.
Post by greeny » Sat Jul 15, 2017 12:12 pm
We're the Gaz shocks on poly or rubber? My rubber are still good after 4/5 years.however my AVOs on poly that are only a year older are totaly knackered bushes oval and the shocks themselves leak like mad added to that the coating they put on is pretty much none existent. On the flipside my Gaz fronts finish still good (yes not as shiny as when fitted) no leaks and work well.
The spax my dad had on his 6 lost their gas after a few years (not to many I might add) so we're replaced with Gaz.
There's probably not a great faultless option out there so I guess it's preference!
At the moment I have old Konis on the rear of my C which once I can afford will be getting removed as they feel awful
Post by scimjim » Sat Jul 15, 2017 1:36 pm
I'm more than happy with my Spax (poly and rubber on different cars) and protech (which are available with rubber, poly or rose jointed - mine are poly). I had an SS1 on AVO poly which had distorted and QRG sent me a full set of replacement bushes FOC (even though I hadn't bought them from him). My white SE5 (AAA) was on spax with poly many years ago and were fine when I sold it (the dampers would only have been about 2 years old though).
Been thanked: 94 times
Post by ScimmyMike » Sat Jul 15, 2017 4:13 pm
Had a set of the poor quality AVO bushes a while ago, AVO replaced foc with a metalastic type, when I rebushed the front suspension and repaired the rear axle mounts after they'd been fitted 3 or so years were still all good.
Post by gtcse8 » Sat Jul 15, 2017 6:41 pm
Pictures say a thousand words.
These were fitted 13 or 14 months ago
pass shock.JPG (61.92 KiB) Viewed 1065 times
shocker top.JPG (62.45 KiB) Viewed 1065 times
passenger shock.JPG (61.79 KiB) Viewed 1065 times
Post by scimjim » Sat Jul 15, 2017 6:42 pm
Look like AVOs - are they NOS because those bushes were supposed to be withdrawn years ago.
Post by gtcse8 » Sat Jul 15, 2017 6:59 pm
Yup Avo`s.
Will look into how long they were on the shelf, but only on the car a short while.
What I can`t get into the manufacturers thick sculls is: OE shockers either use a Bonded steel centre pressed into the eyes, OR a fully bonded Inner and Outer, pressed into the eyes.
These bushes last for many years.
If they bought them In Bulk, the unit cost would be negligible, AND they would not get bad press or have to keep sending crap bushes out for owners to rectify.
Dennis Nicholas
Has thanked: 17 times
Been thanked: 14 times
Post by Dennis Nicholas » Sat Jul 15, 2017 10:03 pm
I was the first person to work with Protech to develope front and back shocks for the 6a. (Mr Avo was just starting to design for them after his bad experience of being pushed out of previous company(s). They used a Jaguar bush modified with extra bushes either side to get the correct width to fit between brackets + SPACERS and to fit the given pin size.......(it still does not seem to have got through that there was a Reliant modification that used spacers fitting into the brackets which meant the bushes were less wide than the SE5 ones........one trader told me to just put the spacers on the outside of the brackets, and another to just force the brackets apart to force the too long bushes into place.....NO NO NO bad engineering. Come on manufacturers make the bushes the correct length and composition........Protech gets my vote with their adjustable spring seat and single adjustment for damping and the bonded bushes modified to fit the Scim. The cost at the time was cheaper than some and more expensive than others (£100 a corner for shock and spring a good few years ago) I had asked for the smaller diameter springs for ease of obtaining.
I still have copies of the drawings they did and which they sent me.
Dennis
Dennis Nicholas(RSSOC)
mick_gaugh
Has thanked: 27 times
Post by mick_gaugh » Sun Jul 16, 2017 10:33 pm
I called AVO last Friday as they are based in the same town as me and requested 4 replacement bushes for the shocks. I told them that I expected much more than two years and very low mileage without experiencing failures as pictured. Their reply, Four replacement bushes can be collected and will cost you £40. Nigel QRG does not have any. :shock:
Mick Gaugh
Post by greeny » Mon Jul 17, 2017 8:07 am
I was told that I couldn't have gratis replacement bushes for our sst as they are oval, so I had to buy a set from Nigel.
Post by AJL Electronics » Mon Jul 17, 2017 8:23 am
mick_gaugh wrote: Their reply, Four replacement bushes can be collected and will cost you £40.
You can have these Mick. I don't have a full set but it may help a bit...
Actually I can't show you a picture because of an error message... Sorry, the board attachment quota has been reached.
It is a set of bushes that I bought when doing the Swiss Middlebridge. They consist of Metalastic bushes and collars to adapt. I have two bushes and three sets of collars.
