Gte track rod end thread
Has thanked: 187 times
Been thanked: 94 times
Post by MikeyBikey » Wed Jun 07, 2017 9:41 pm
Recently purchased a pair of QH track rod ends advertised for a 5a. However upon receipt the thread was much coarser than my steering rack. Thus I cannot use them. Was there more than one thread type used?
Been thanked: 113 times
Re: Gte track rod end thread
Post by ScimmyMike » Wed Jun 07, 2017 9:52 pm
I've been there, done that, sat in a box in garage, only place to get them sort of things rightare QRG and Walkers it seems
Been thanked: 80 times
Post by b.c.flat hat » Wed Jun 07, 2017 10:15 pm
Yerse mate, I've had trouble int' past wi' this. Mine turned out t' be M14 x 2.00mm pitch, Firstline FTR 4040. Some TREs have tapers too small but correct thread! Nightmare! Hope this helps, Crusty.
Been thanked: 77 times
Post by gtcse8 » Wed Jun 07, 2017 11:22 pm
9/16 x 18tpi UNF for se5a.
Firstline FTR 4019, Quinton Hazell QR1153S, Motoquip VSS114.
M14 x 2.00 pitch on se6 onwards.
FIRSTLINE FTR4065, Quinten Hazell QR1556S, Motoquip VSS120.
As crusty says there are quite a few combinations that "Seem" to fit, but you must use the correct combination of Thread and taper, Brian`s turned out to be a Ford fitment, probably from an earlier rebuild as it`s a common misnomer that Scimitars use Ford running gear.
