SS1 1600 inducator relay
kevincooper
Post by kevincooper » Sat Mar 11, 2017 4:13 pm
Afternoon All
Can anyone tell me where the indicator relay unit is on the SS1. I have found the hazard and low fuel relays behind the dashboard to the right of the steering column, but cannot find the indicator. As they are not working I guess it is that at fault.
Many thanks
Kevin
Kevin Cooper
Chairman
Insurance Valuations Officer
DVLA Liaison Officer
GTC
SE5a sprint car - Blue Dragon
SE5a waiting for restoration (Little Red Devil - Reg 666L)
Been thanked: 438 times
Re: SS1 1600 inducator relay
Post by peter freeman » Sat Mar 11, 2017 5:02 pm
Its behind the drivers side of the dash somewhere - I cannot remember exactly where. Have you tried operating the hazard switch a few times as its often dirt on its contacts which stops the normal indicators working.
kevincooper
Post by kevincooper » Sat Mar 11, 2017 5:06 pm
Hi Pete
The hazards are working fine, it is the indicators that refuse to work, I have tried working the indicator switch up and down many times, but nothing. As I said I have found the hazard and low fuel relays, but cannot see or feel the indicator.
Kevin
Kevin Cooper
Chairman
GTC
Has thanked: 189 times
Been thanked: 1281 times
Post by scimjim » Sat Mar 11, 2017 5:07 pm
There's only one relay on the small sports for indicators and hazards and originally, it's in the steering column cowl. Relays on the A post crossbar are low fuel and low water (along with low oil module on early cars). 6DA unit for intermittent wipers is mounted on the (bracket alongside) steering column.
Has thanked: 132 times
Been thanked: 875 times
Post by philhoward » Sat Mar 11, 2017 5:47 pm
Keep exercising the Hazard switch (and try to pull it out when "off") as the indicators are disabled if the Hazard switch is on and vice versa.
Post by scimjim » Sat Mar 11, 2017 7:19 pm
so if the hazards are working, it's either the indicator switch or the hazard switch. As the hazard switch gets used so little (hopefully :-)) that's normally the culprit as Peter & Phil say.
kevincooper
Post by kevincooper » Sat Mar 11, 2017 8:51 pm
Thanks all
I will try it tomorrow, hopefully the switch is the culprit.
Kevin
Kevin Cooper
Chairman
GTC
