Selector lever clips
Terry H
Been thanked: 42 times
Post by Terry H » Tue Sep 18, 2012 10:24 am
Hi All,
I've been looking for some seletor lever clips as one of mine is broken. I just came upon these http://www.ebay.co.uk/itm/221048498671? ... 1438.l2649 on Ebay, They look exactly the same but are they the same size. I know a few of you have landrovers, would it be possible for someone to check if they are the same. This could be one for the alternative parts book.
Regards Terry H
1185
Terry H
Re: Selector lever clips
Post by Terry H » Tue Sep 18, 2012 5:37 pm
Anyone think these may be the same items. My photo (bottom one) is not very good as focusing on my camera isn't working properly. I need someone with a Defender to check the size if possible please.
Regards Terry H
1185
Picture 252.jpg (60.74 KiB) Viewed 7708 times
Been thanked: 66 times
Post by Scimher » Wed Sep 19, 2012 3:32 am
Blimey - the thick end of six quid to despatch.......!!
Been thanked: 840 times
Post by scimjim » Wed Sep 19, 2012 6:16 am
Probably cheaper from Land Rover themselves?
Terry H
Post by Terry H » Wed Sep 19, 2012 7:48 am
Yes I was a bit shocked by that , the clip in the ad is prrobably huge and weighs about a kilo. I'm going to nip down to my local Landrover dealer some time today and ask if I can have a look at one. I was hoping someone with a defender on here could have saved me the trouble though.
Regards Terry H
1185
Terry H
Post by Terry H » Sat Sep 22, 2012 11:06 am
Just an update on these clips. I've found that the Defender TD5 Diff lock lever retaining clip FRC8548 is the same clip for the gear shift linkage on the side panel and are available from your friendly Landrover parts dealer for the princely sum of 94p each. I think this should be added to the alterparts book/list/file.
Regards Terry H
1185
Picture 255.jpg (76.23 KiB) Viewed 7635 times
Been thanked: 534 times
Post by philhoward » Sat Sep 22, 2012 11:18 am
Cracking find, Terry!
Jim - please update Alterpart!
Terry H
Post by Terry H » Sat Sep 22, 2012 11:30 am
Worth making a note of the Landrover part number as well. Landrover here in Newport didn't have any and couldn't tell me if they were the same or no so I had to go to Caerphilly depot and get some.
Regards Terry H
1185
Post by Scimher » Sun Sep 23, 2012 5:17 pm
Well done, Terry......I had to use the type of 'spring clip' that holds the cotter pin on axle stands......!!!!!!!!!!!
Terry H
Post by Terry H » Sat Sep 29, 2012 7:17 pm
Having fitted the side panel today I can confirm that these Defender TD5 Diff lock lever retaining clip, Landrover part number FRC8548, do fit perfectly. I would have put them in the Alternative parts file/folder whatever but cant find it on the site.
Regards Terry H
1185
landy109 s2a
Post by landy109 s2a » Thu Aug 29, 2013 5:31 pm
Yes correct Landrover will fit.I think i'm correct in saying that the 2 rod gearbox requires 5 clips to do a proper overhaul.On the gearbox plan, they are at points 5 -12- 13- 18- 33. Number 33 is not on the index page,but is on the plan.Between 16 & 19.Reliant logic :lol:
Post by scimjim » Thu Aug 29, 2013 5:36 pm
they don't fit the 2 rod box bellcranks - they're much bigger. QRG have stock.
malthouse
Location: Castle Coombe, Wiltshire Email :- dnp_uk@yahoo.co.uk
Has thanked: 52 times
Post by malthouse » Thu Aug 29, 2013 8:57 pm
Think I have a couple of these in the workshop There for free inc free postage how many do you want?.
malthouse
Post by malthouse » Thu Aug 29, 2013 9:00 pm
HI , I am positive I have a couple of these in the garage, dont want anything for them and free poastge to you as well !!
how many do you want ?.
Post by scimjim » Thu Aug 29, 2013 9:13 pm
the threads a year old, I think Terry is sorted now :-)
