spring rates
Has thanked: 129 times
Been thanked: 938 times
Re: spring rates
Post by scimjim » Wed Nov 14, 2012 12:19 pm
The shock absorber simply dampens the spring's rebound - the spring takes the weight, so for the same pothole, a 180lb spring on a GTE will deflect further than a 180lb spring on an SS1. To make the two examples rebound at the same frequency the GTE damper would need to be set harder - that's nothing to do with the spring dia but the vehicle's weight, the amount of deflection and the spring's "poundage" (which is composition, wire dia and number of coils).
Coco La Blanc
Re: spring rates
Post by Coco La Blanc » Wed Nov 14, 2012 12:25 pm
Did you just agree with me - or not ? :) :lol: :)
Re: spring rates
Post by scimjim » Wed Nov 14, 2012 1:25 pm
not sure - you said "why go to a 2.25" on the 5a" then started comparing it to the weight of a small sports which is nothing to do with spring ID?
Has thanked: 136 times
Been thanked: 502 times
Re: spring rates
Post by Roger Pennington » Wed Nov 14, 2012 2:42 pm
And the point I'm making is that the actual damper is more often than not, the same - the difference depends on which spring seats are screwed onto the external thread.
Coco La Blanc
Re: spring rates
Post by Coco La Blanc » Wed Nov 14, 2012 2:50 pm
And I still agree with me - and I know what I meant !
Viv
Has thanked: 50 times
Been thanked: 589 times
Re: spring rates
Post by philhoward » Tue May 10, 2016 12:33 pm
Useful info from another thread added for posterity:
Does anyone know what the correct distance between the eyes/mountings on a car riding at the correct height is
13.64 inches (346.4 mm)
Handy info if you want to make a solid replacement for the dampers to check camber and castor angles without spring/ dampers fitted (or to check your current setup for possible ride height issues).
